Parting Out 1977 FJ40 parts
Parting out a nice 1977 FJ40 tub is gone , hood is gone trans tunnel, fenders, engine is sold pending funds.
I have all the interior parts and chassis parts including a shackle reversal with 4" lift front and rear. disc brake conversion parts, two 4:10 diffs, rear axle housing, 4 speed trans, bellhousing, flywheel,starter water pump, e brake parts, drag link, intake manifold, exhaust manifold, engine lift hooks, exhaust system down pipe, oil cooler, smog pump,wire harness, alternator, alt bracket, fan, fan clutch, all relays, coil igniter, carb , carb spacer, heat riser tube, heat valve, dash switches and cables (headlight switch SOLD) tail light enclosures, tail light shields, accelerator linkage, shifter boots, seat belts, jump seats, glove box door, front bumper brackets, ash tray, t stat housing, fan shroud perfect, rear heater, rear heater hoses, master cylinder, all splash guards, under dash ducts, speedo cable , e brake handle and cable,
I am looking for the air vent knob plus the cable/rod connected to the knob to open/close the fresh air vent louvre located in front of windscreen.
Igniter functional, pic, and price?
Heater water control valve?(I think you listed this as a part-any idea if the thing leaks internally?)
It does not leak externally and it switches open and closed. I never ran the heat so don't know if it closes internally
Ok. What are you asking for the valve? (ship to 33920)
