1970 front drum brake flex line (1 Viewer)
Kenosha,WI
The front rubber brake lines are both blocked solid. Female end to receive hardline at frame is 9mm, the male end that goes into a T fitting on the drum back plate is a 11mm 1.25 thread pitch. Anyone have a source for this line. Rock auto was wrong and cruiser corps says it should be a 9mm on both ends, but it’s not. Truck tag is 12/70. Line is 17.25” long.
I think I have what you need.... give me an hour or so and I'll take pictures
Now you can see the pattern of how Cruiser Outfitters uses the last 5 digits of the latest Toyota parts.
Hoped this helped
Ernie
a bunch of the posts above show and give info for the late 1970 dual circuit setup
almost positive the OP needs the single circuit line which is very different than the next version.
mid year 1970 was a change over to boosted and dual circuit brakes versus the early single circuit brakes
on a side note, you really should consider upgrading to a dual circuit brake system
My door vin plate says Dec 1970, but all the parts I need for this appear to be for 7/70 or earlier. Frame number matches body tag. I ordered lines.
Mr. T was funny about this stuff, I have US spec., 6/70 all original (36k miles) build LC but Mr. T used more of the latter parts-I've got 10mm lines too.
