I'm still grappling with this one. I get the motor side of the equation, but not the switch. I have a 66 and can't get a switch for it, so I thought I'd try a switch from a 68-72, which is available. I don't know when the two motor scenario changed to one with the arm, but it looks like right about 68. I have yet to get a positive ID on a picture of a switch from a 66. If the ones I THINK are from a 66 the switch looks to have the same terminals as the 68 switch but are soldered on the switch and terminate to a plug vs having spade connectors on the top of the switch. The switch for the 68, I'm pretty sure is for a two speed scenario. I haven't been able to confirm that on the 66.
The 68 switch has terminals labeled +1, +2, S, and (-) neg. Coolerman's drawing suggests three usable terminals on the switch.
Pic in my manual has S (LB- blue/white) at the top, negative (W/B- white/black) in the middle and + (LB-Blue/black) on the bottom. Coolerman has P listed in the center terminal that Toyota calls Neg (-). P for Park I'm guessing. His wire colors are consistent with Toyota, though the switch in his drawing has no connection for the LB (blue/black) wire that hits the + terminal. Coleman, if you're out there, how is your switch drawing labeled for +,-, S?
I DO know that, through using a power probe, the blue/white wires control power to run the motors. That must make the blue/black wire the other + that controls the Park function (deduced by others). I get the white/black body ground, though it may split off to also ground the switch. Does the S on the switch get just the 12V feed wire, or does it also get either the LW (blue/white) ) or LB (blue/black) wires? A continuity test gets a constant continuity between the S and +1 terminals on my 68 switch, regardless of how the with is operated- On/Off. The PO of my truck had the wiper motors connected to separate toggle switches, so I don't have a reference point. This is the pic for the 68 switch. W is to the washer motor, so we'll disregard this for the moment.
Any help is appreciate. Just finished a re-wire and this is the last gremlin to solve for.
Thanks.
