- Joined
- Sep 25, 2011
- Threads
- 89
- Messages
- 3,678
- Location
- Harbour City, the New Southern Wales
- Website
- www.freewayoneentertainment.com
Righty-o.
Thanks. DTM epoxy sealer, surfacer, and final sealer are PPG ShopLine. Top coat is PPG DCC single stage.Looks fantastic! What paint products are you using?
Not much progress over the Summer months but have just started to spend some time on it again. Mostly been concentrating on the wiring. Have had the wiring harness in, then out, then started over. I'm using an aftermarket harness from Summit. Didn't know it at the time, but I'm pretty sure its an EZ Wire harness. Would have not chosen this one if I had seen it first. Number of things I don't like, which is why I pulled it back out and have started over. Still using the same harness, but removed a number of circuits and modified the flasher pigtails, horn relay pigtail, ignition switch connectors, and added a main fuse instead of the supplied fusible link.Awfully quiet here!
Need an update Mike!
