1962 Brake Master Cylinder Rebuild KIt (Single Circuit)
Phoenix, AZ
Website
fj40bugcatcher.dyndns.org
My rig sits idle for awhile so as many of you know that brings in another problem of the Master Cylinder leaking from condensation inside the Master Cylinder. From what info I have learned, that is an inherent problem or property of Brake fluid and the lack of the vehicle being used.
So...I got tired of buying new Brake Master Cylinders so I had a stainless steel sleeve put in one of my Master Cylinders. Hopefully that may sole the leak issue.
I tried using some old pistons, seals from old leaking units, but of the two I tried it still leaked from the pedal side. I guess the seals must get damaged from the condensation or maybe just shrink up from sitting around so long?
Anyways, I'm looking for a rebuild kit. I know SOR carries one for $35.90. That seems like a high price. Normal kits here locally run $17.00. Is there a better source for this kit?
There is a 62 rebuild from the Netherlands in the 25 section. Search in that section for your answers. I believe the tin cup version is the same as the later plastic reservoir.
