1964 fj45 brake master rebuild kit needed
Will the complete Master Cylinder allow the reservoir to change for the metal original for an original look ?
Yup! We need to add this from our old site.
OEM Toyota Single Reservoir Master Cylinder - Features plastic reservoir, re-use old reservoir for period correct early models. Includes push-rod & clevis.
(Fits 58'-7/70' FJ4x)
Part# BKN35011OEM
Regarding rebuild-tech, I've always wondered how far can you go with a hydraulic parts? Realistically, honing-out the cylinder to the depth of rust pits is usually unfruitful. I've done it before, but, most of the cast iron parts are either just getting a cosmetic resurface on the bore, or they get taken out of service. I could have easily just have done it with scotch-brite, and not a cylinder hone. I've performed rebuilds where it needed soft parts, or just painting / cleaning, so rebuild kits are certainly appreciated, and I'm always intrigued when I find one for sale, but if it is a leaking part, they almost always need replacement.
I always figured that there is someone out there who can strip all the corrosion from the rust cavities in the bores and fill them with lead / brass, or epoxy, then hone the cylinder back to a smooth bore. Like a dentist, but for your car. Probably not, so instead, I'm bleeding brakes and clutches at least once a year to prevent corrosion. I can't stand looking at stained hydraulic fluid in the reservoirs; I'd consider the clear plastic a rational update on the '64 MC. On the other cars, I lift the vehicle and remove a wheel to not struggle getting to bleeders; I appreciate that the 40 needs none of that to perform bleeding.
There are businesses out there that will sleeve wheel cylinders and master cylinders. I have no idea of cost comparison from a sleeve re work versus new, if available. If you own an old or rare vehicle and replacement parts aren't available, then sleeving may be a good option.
There are lots of folks that bore out cylinders, carb slides and sleeve them etc - it is much easier to repair than cast and machine new. I really like watching Curtis of Cutting Edge Engineering bore out heavy equipment eyes, rotary weld them up and then return them to stock size
whats the story on the early clutch master?
gone forever or you might get some back in stock?
Nope, Olly is prepping some more
