Wanted 13BT Upper Thermostat Housing (Outlet, Water)
Boise, Id
Looking for Toyota Part Number 16331-58030. It shows available on a few sites, but when I tried to order it, I got a message saying the part has been discontinued.
Outlet points to the U.S. Driver's Side, has two ports on the U.S. Passenger's side for turbo cooling lines.
Long shot, I know.
Thanks,
Dan
Cruiserparts.net has one listed on there site. I see mixed things about them in the "Beware" section.
Thanks. The one they have listed (at least in their 'new' parts section) is the one without the turbo cooling line ports. I've dealt with them before, I am wary. They usually come through, but it can be painful.
Dan
If the main outlet housing casting is OK and the problem is corroded hose tubes, the tubes will easily pull out when the housing is heated slightly with a torch, then it's easy to thread the holes to accept standard brass hose barbs.
