so nobody knows if any 8" diff will fit in these? minitruck? HZJ front? KZs are soo rare, here anyway.
then you could swap from 4.8s to 4.10s without having to setup the gears, just swap the entire diffs. i'm dreaming of a similar swap as n0ferz and my goal would be around 2250rpm @ 110 kmh with a 1PZ instead of 3B. i wouldn't need the high pinion for light trail/DD.
well, yah it does make a difference but be sure to post up your gear swap so i can be proven wrong ...
I think I have found that thread, thanks for the info.
I wonder what is the model of the stock turbo the 13b comes with? Also what is a good turbo size that I can put on this engine??
80 sereis front diff bolts in the front of your LJ
not sure about the rear.
i know where there is a minitruck rear diff with e/locker, 4.56 and 20K on it ... it was brand new factory.
