Yeah, it shows how important it is to reduce parasitic losses. It would be interesting to know idle fuel consumption on various vehicles.
If I can get lowish EGT's and huge torque at ~ 1600rpm, I will be very happy since that should equate to a good bsfc result. I should aim for the 1.9 TDi EGT curve.
I did consider destroking my engine at one stage..... I just cant make up my mind. Maximize the potential capacity or make it less. I wont know what I want to do for sure until I get the twin turbo running!
You can get a 7psi back pulse in the exhaust, so in effect you can supercharge it in the resonance range - to good effect!
Idle fuel consumption on the VW 2.0tdi is 0.9 litres per hour according to the computer. This is with the AC running. That's the only result I have right now.
The higher your EGT's are, they higher efficiency you'll get from both combustion and from the turbocharger. After all the goal is to expand air. So attempting low EGT's by pumping extra air will cost you in fuel economy and power/torque.
Just pick a level that you consider safe for your engine and use that. I run 750C peak, for continuous loads (long hills) I keep it around 650C. The occasional excursion over 800C too :whoops: but it seems to survive fine.
