1HD-T came out by yanmar with over 650nm and 190kw, 30psi boost. The 4 valve using the same rods has over 700nm.
Std conrods, 15.5 compression pistons. Some pistons had bronze inserts in them, others do not.
Diesels are generally overbuilt, the totally standard naturally aspirated TD42 Nissan motor (IDI) with 22:1 compression has often been bosted to 30psi. Just today I was discussing this motor with united Injection here in Perth, they have had one recently to 200rwkw - you read correctly. Head hasnt been off block, totally stock, but interccoled, 12mm plunger VE pump, high flowed turbo. They race this thing in a detuned state at 550nm and 158rwkw. I have watched it race (2 weekends ago) and it doesnt smoke much, but really hauls!
I also met with Andy and Diesel tech in Melbourne. He has done a compound turbo 1HDT and also a TD42. The TD42 had a GT2860RS for the small turbo and a GT30R (I think) for the big one. The 1HDT used the stock small turbo and the GT30R for the big one.
As for numbers;
1HD-T; 40psi boost, no intercooler, no smoke, 138rwkw, std pump, no problems but Wife needed car back
TD42; 55psi boost, no intercooler, no smoke, 177rwkw, modded pump and a conrod out the side of the block............
Having seen inside a 1HDT, I would feel comfortable running 50psi
I think I am taking a risk with the 12H-T
besides, we shouldnt be talking boost, it is the size of the bang that breaks the rods......
Now, a compound turboed 1HD-FT with fully modded pump - that would be fantastic!!!
The other exception being the Mercedes diesels, which were all IDI until the CDI models. 1HZ's do not share the same reputation....
Anyway, for me it is as much about efficiency as it is power, and that rules out IDI.
I checked out the book today, had a bit of a read. Very theoretical and comprehensive. One note was that was that in theory fro 2:1 ratio, the turbine exducer cross sectuional area for the big turbo should be twice that of a small, but then it said tests showed that in practice, there was little difference when using ratios of 1.4-1.7:1..... The CT26 exducer measures at 52mm (I need to check that, some sites say 50.8mm) and the GT25 measures at 48mm but a better design. So there may be a mismatch on my turbine choice for the big one - but I kind of thought that already.
I plan to get the book out shortly, it is less than a 10 min walk from where I work though.
140cc from std pump.... thats huge.
By the way, can you tell me if there is a relationship between Cummins and Isuzu?? I get confused when I read about the 4BT and 6BT Cummins and then the 4BT Isuzu...... What are the differences, if any?
I was considering it, but this engine is my budget build because there are areas of experimentation. I figured that with a cast iron head an block, it is of less value than for alloy. With this project I am looking at cost to benefit ratio.
As an example, once I have maxed out the stock injector pump, I will likely use LPG for additional power. In this way I have a degree of control (electronic) that my pump doesnt offer.
If the std pump can delivere 500-600nm and I have extra 30% from LPG, I am in very happy territory.
yesterday I was playing with a friends 1HD-T that has intercooler, high flow turbo, 3" exhaust (basically an exact copy of my previous ride) andit is interesting. When I "only just" tuned the smoke out, it was clear the smoke increased when the LPG came on. This is what you would expect, however the internet is full of false info.....
I have done the same experiment that shakes the engine on it's mounts.
It is nothing more than the revs increasing and fuel is cut back by the idle feedback in the pump, so it starts to miss....simple.
When meterd in though, runs nicely and smoother than std.
I know what detonation is and sounds like too.
