- Thread starter
- #101
You appear to be not giving due consideration to the impact of mixture ratios on the combustion event. Unless the engine is running in HCCI mode, which requires a different cam profile on the exhaust or a restricted exhaust port flow, the engine will detonate with rich mixtures. By rich I mean greater than ~ 60:1.........
When the mixture is leaner than 60:1 at std 18:1 compression, the fumigated mix needs a higher actication energy than the heat of compression alone to ignite the mix.
This is why (taken from a forum you suggested in an earlier post) the Engineering Gentleman Franz or something like that quoted for Sparki Ignition (SI) LPG engine something very interesting:
"One item that seems to be overlooked is that when a gaseous fueled engine goes lean, the exhaust temps also LOWER, and when the mixture goes rich, the temps RAISE. There is no evaporative effect with the gaseous fuel. I ran one 6.0 liter engine to L=1.9 and the exhaust temps were around 800 deg F! This was at 3000 rpm, 30 psi turbo boost, and about 290 bhp. Bringing the L ratio closer to 1.0 raised the power levels, but also the exhaust temps, and the NOx went through the roof!"
This is due to the same principles that he was able to run the SI engine at 30psi boost without detonation.
I don't know about your obviously scientific background, but mine includes chemistry with covered kinetcis of chemical reactions. What is observed in the above quoted based on practice is clearly what should be expected in theory.
Also note, the above referenced SI engine is likely as efficient as an equivalent Diesel, possibly moreso and ran at ~ 30:1 based on my rudimentary back calc……
Anyway, back to your last post, I propose that if combustion were to occur the way you state, detonation would always the inevitable result, and that is clearly not experienced in practice - what I see in practice is what I would expect based on my understanding of theory.
Note that I say "my understanding", this is a caveat......
Cheers
Cheers
