@Franken470 so how is the rclt install going?
Well, hit a couple snags and one of them the same thing that probably will end up keeping @Vlad install ahead of mine. We both had worn motor mounts causing the motor to rest on the steering rack, I have a red neck solution of running some washers until the mounts arrive but I also sold my wheel setup and had planned on running those until I got gears. I have to get a set of wheels ASAP to get back on the road is option 2. Photos and videos coming soon.@Franken470 so how is the rclt install going?
It’s only a few days. I’m just being stubborn leaving 2 tires mounted for fitment while I wait on gears and trim the rear to stuff said mounted 37” tires. Thank you for the offer.I’ve got some FZJ80 wheels if those will fit. You can borrow them if you need a temp solution.
Full droop preset for limit strap install tomorrow.
Almost as big as a LS swapped 80 on 40’sThat’s going to be one big ass gx
No need. I’ve got about 3 hours left and I’m waiting for 1 wheel which will be here Friday. I wanted to leave my pair of 37” tires mounted fit ease of fitment and fab my new swing out.@Franken470 did you take off the week to complete this beast?
Have now spent better part of an hour taking with big mike about a few things we have found on the kit. 1 being that I am the only fitment known to be running an existing body lift which is possibly putting the steering in a bind. I’ve got a couple guys coming by to take a look this week and see if we need to make a custom shaft on a CNC lathe or rebuild existing… still some work to go but really excited.@Franken470 you get some tires on that monster yet? It seen daylight yet?
