- Thread starter
- #21
OK...connected the stock rear taillights. Had to clean the mounting holes on the passenger side to get a good ground. The drivers side wouldn't ground through the bracket/crossmember even after clean the surfaces, so I ran a ground wire from one of the light mounting studs and the bracket mounting bolts. After this, I still have the t/s indicators lighting up with the lights and everything flashes with the turn signals on. When I have the right turn signal on, the right rear flashes brighter than the left rear and visa versa.
All wiring is original now, with the exception of the t/s switch connector. I found the old (broken) t/s switch with the correct connector and all the bullet connector jumpers are connected to the correct colors.
