More width, stronger than my 80 SF, no C-clips, brake upgrade.........but do the links and coil mounts line up?
so you are going to have 5 lug rear and six lug front rims?
Having 2 spare tires would suck. Either use an 80 series rear FF axle or forget it. I don't see a 100 series axle, and all the work it would require, to be an upgrade.
All LCs up to the 200 series (it may also) use the 9.5" rear chunk. I'm not worried about the diffs though, I'm wondering if anyone (Slee?? Dan??) knows if the brackets, or more importantly, the coil pads match/line-up with each other....
I'm not sure if the 100 shares the same axle as the tundra, but we could always use pictures. 80 vs tundra FJcruiser vs 80
I do not believe the 100 semi floater is any weaker than the full floater. In fact, probably stronger if you look at the size of the axle shafts. However if you are into spares, carrying a 100 spare axle shaft it is a pain. You either have to carry a complete assembly with brake backing plate etc attached (1 each for both sides) or you are going to need a serious press and the knowledge to swap just the shaft.
The FF has a huge advantage in that it is easier to swap and way smaller to take with you.
