Then at least you would have matching wheels and you'd pick up Shotts as a wheeling buddy.It will not be a direct bolt in.
Doug, Drew; I understand all of those issues, IF it doesn't bolt in....but when the hell is someone gonna tell me straight up that it doesn't fit and with pictures, measurements, spec sheet, something....
It won't bolt in. It is wider and the links are at different angles, so at least those mounts will be off. It doesn't mean that it could not be made to work, but I do not think it is worth the effort. Use a 80 series rear axle with ARB and then use Poly rear axles and call it good.
The track width will also be 5" wider than the front. What are you going to do about that.
it seems to me that no one has tried it for various good reasons. So instead of crying about how no one is answering your question, go out buy an axle and report back. Someone has to be the first to do a mod and in this case it would seem to be you.
So you need to do the research yourself and then make the call and live with the results.
Both out of FSM's downloaded off of links from this site, this is elementary swap research and if it causing you issues at this point...
