- Joined
- Jul 31, 2007
- Threads
- 13
- Messages
- 195
- Location
- Portland, Oregon
- Website
- www.oregonphotosafaris.com
- Thread starter
- #121
Today I installed the ARB Bull Bar and ARB Roof Rack.
The Bull Bar would have been easy if the instructions were written better. There were no explanations as to which of the 100 bolts, nuts, and washers were which and to make matters worse when I went through the supplies list and figured it out, the washers didn't fit on some of the bolts they were supposed to so I had to hammer them on with two hammers. Eventually the washers fit. Didn't damage anything, freaking headache (or so I thought).
Overall it took about an hour of actual installation. Then add on the time it took me to figure out the freaking instructions and get those freaking washers on the bolts and it was a 6 hour job including a trip to Home Depot to try to figure out the washer thing. I guess it wasn't the washer, it was the bolt.
Some of the bolts that were for the same purpose had heads with slightly different size heads. I guess not everyone can make stuff as easy to assemble as Ikea.
Did I mention the inside of the Bull Bar had rust in the weld seams? Yea. A brand new bull bar straight from Australia and it has rust starting inside already. So I sprayed the crap out of the inside with Rust-Olium, problem solved. But kind of troublesome for a new peice of auto equipment. I usually don't put parts on my rig that have rust!
Then comes the roof rack. I ordered the roof rack from 4x4 connection and ARB had it in stock but had to have the install kit flown in from Australia. ARB Washington was in on the whole transaction since they were shipping directly to me instead of to 4x4 and them to me.
So I go to install the roof rack and the rack brackets are too short to reach the front mount brackets on my LC. I call ARB and they say that the long roof rack doesn't work on US Land Cruisers and that only the short roof racks work.
Needless to day I was pissed OFF.
After I let him know how dissatisfied I was.
He told me that there is no kit to fit a full size roof rack to a USA LC. I'd have to return the roof rack and kit and get the smaller rack and kit.
I asked why ARB sells these in the USA if they don't work. He didn't know. It sounds a bit more polite than the actual conversation was. He was apologetic, I was livid to say the least.
So I'm not returning it, I attached it using the rear 4 mount points. The front two mount points on my LC are under the front of the rack though they aren't under the mounting points on the rack. So I'm going to mount the foot to the LC and U bolt the rack to it. It should work fine.
Oh yea another thing, they require you use the mounting bolts that are on your LC if you don't have a roof rack. Did anyone buy a LC without a roof rack, they don't come without a roof rack! So I had to make another trip to an auto parts store to get the metric bolts that fit in there.
My total actual working time on the roof rack, 20 minutes. Total with travel and calls to ARB and having a f-ing melt down and aneurism 3 hours.
So to say that my experience so far with ARB and 4x4 Connection is less than stellar is an understatement. I would have bought this stuff from Slee, but every time I called to place an order I got an answering machine, and I'm too impatient for machines. After a couple tries, I went with 4x4 connection. They should have known about the roof racks.
So tomorrow I tackle the Tbars, springs, and shocks. I can't imagine it will be much worse than today was. We'll see.
