Just did this on my 98 LC so it is fresh in my mind took exactly 3hrs and I'm slow, If anyone has basic tips to add please do... I've done this before but not often enough to "do it without thinking" I should add it helps to have a milk crate to stand on...
1. remove plastic engine cover (10mm socket)
1a. remove wires from your battery 10mm
2. remove airbox complete from throttle body to filter cover you can do this in one piece(10mm socket)
2a. remove serpentine belt 14mm wrench on tension pulley
3. remove front skid pan (Deep 12mm socket)
4. remove right/pass side radiator hose (catch coolant in large clean bucket for reuse) 5/16 socket
5. remove 2 bolts and 1 nut that hold power steering pump (14mm deep socket)
5a. with a cord or coat hanger pull and tie the pump up and forward
you will need to lift the PS reservoir out of its cradle
6. from above you can remove the main wire to the alt 10mm
7. from below you can now remove the 14mm nut and 14mm bolt that hold the alt. on
8. slide alt forward off mounting stud and turn alt. so you have access to the rear connector
9. it helps at this point to have some extra light and needle nose pliers
you will need to squeeze the connector to release it I had to use the pliers for this... I then had to lightly pry around the connector with a small pick tool kinda like a dental pick to help pull the connector free...
10. if twisted and pulled just right you can now remove the alt. from below
11. Push and twist new alt up past rad. shroud and ps hoses the rest is
the reverse of this except you can go ahead and install the main power wire to the alt from below but wait to tighten it from above after install, do install the main plug on back of alt before fitting alt on mounting stud...
NOTES: my new (rebuilt denso) had a larger main power stud than stock so i had to drill out the lug on the wire harness to fit and it required a 13mm wrench vs the stk 10mm, MY rebuilt did not have the extra dust shield on the back so I used my old one and I used the small metal tab on the side that the wires clip to from my old unit... neither of these are required but toyota put them there so I put them back... I also had a small length of pipe to slide over my ratchet while breaking the PS and alt bolts loose
job.
