100 Series Land Cruiser Rear Lower Control Arms
BTW John, a higher lift actually exposes the arms more in a vertical plane and makes them more vulnerable to hitting rocks, not less. See, you shouldn't have skipped all those geometry classes in skool! :grinpimp:
edit: But, back to the original point, it's still better in my opinion to bend a control arm than a prop shaft. Only one of those has a real chance of stranding you.
I'll put my very simple .02 in....
I came off a ledge, slammed onto the arms, yes, it was a flat ledge, I had to back down it due to not being able to clear the ledge infront of me.
If I had not landed on my arms, I would of nailed the prop shaft. resting on a slider on a ledge will allow the rear axle to droop, further lowering the shaft, I have barber polled mine on a few rocks, I would not put high clearance arms on mine. I would rather be stopped by the mount or hear it grind rather than ruining a driveshaft... which I have just about done... except it is still attached somehow.
With all the bent rear LCA; if everyone had high clearance rear LCA how many drive line would have been lost? You can mod your LCA to take a hard hit but not a lot of choices with a drive line.
Good reason not to go with high clearance LCA. If you are in a situation where you bend a rear LCA could you even get out without a rear drive line. I would not like to do a 4+ trail with only one drive line.
Arms should be used as under carriage sliders if they are built right.
I love mine as sliders. I love hammering on them, sliding down huge ledges on them and just plain ole bashing on them.
That's the way control arms should be used--to control the bashing of the truck!
Back to your regularly scheduled 100 series pee festival.
:lol:
OP here...
1. Are the 80's OEM RLCAs stronger than the 100's?
2. Are they the same length?
3. A 100 owner just needs 80 mounting nuts and bolts and to enlarge the holes in the frame and axle brackets and an 80 RLCA is a bolt on, right?
...as you were.
OP here...
Not sure of wall thickness differences: I suspect they are the same. The 80's like the 100's bend fairly easily.
Yes.
Correct.
...as you were.
i'd hate to be on johns bi-annual offroad day trip...stopping for poser shots every 25ft.
Well I'm sure glad I got a 100 series, this thread has been most enjoyable.. :lol:
You have to admit we're an entertaining lot if nothing else :D
entertaining lot indeed, but let's stick to entertaining tech OK! :)
