100 Series General Tech and Classifieds (3 Viewers)
thanks Ron....may go ahead and remove it while fixing my cat. converter rattle with some hose clamps....gotta love the faq
next questions:
1. Toyota Parts and Service
how come my 1999 schedule only goes up to 122k? I have 196k...is there another source for higher mileage service?
2. when I go from park or reverse to drive with foot firmly on brake pedal I get a driveline "shudder". It's not titanic hitting iceberg loud but it's noticeable....is this normal? change tcase fluid and see if it is still there?
Don't know about the first one, but the second one can be minimized by greasing the driveshaft. If you search the 100 forum using driveline thunk, you will find what you need to do.
The 100 forum has tons of info in the FAQ. I would suggest going there first before posting questions here. Also, search just the 100 forum. Lot more folks over there.....
reading FAQ while off work today is what has generated all the questions.....thanks Martin will dig deeper in FAQ.
next questions:
I have the same clunk. Need to grease it.
Previous owner used the pages past 122k to roll doobies
^ if you need a grease gun or zerk locations let me know.....ive been reading and have mucho intel on it (thanks Martin)
Nolen be careful or ill call YOU for help with my fluid baseline, slider install party.
https://forum.ih8mud.com/100-series-cruisers/401590-official-clunk-thunk-driveshaft-thread.html
this thread is huge.
My summary -- put grease in the points shown on schematic until it oozes out like the picture I attached. This pushes all old grease (designed to trap sand, water, etc.) out and ensures you have all new grease.
page 2 of this thread fires up the argument you shouldn't "overfill" and when to do it. Essentially you can't overfill IMHO as the gunk will come out not rupture a seal or lock up the shaft as some suggest.
What is clear is that it should be done ATLEAST at every oil change. since 100% of soccer mom's know squat and most stealerships (see thread) DON'T grease zerks per Mr. T. I feel missing it once or twice is no biggie.
Regular greasing will help keep it lubbed and help with THE THUD (per thread). I think at oil changes is plenty unless you live in a very dusty environment or do lots of water crossings.
Having discussed frequency you are welcome to use my gun but you may be better off hitting a parts store for a $15-$25 gun to keep in the garage. Thread also discusses type of grease. There are hundreds of types of Molly grease and you can read the thread for what you want to use.
probably way more info. than you wanted but I assume some other new to 100 guys like Andy and others may benefit from my boredom.
I can bring my gun to the meeting this week....let me know
--edit-- picture is front drive shaft and in upper right corner you can see the grease line hooked onto the slide yoke and just a little grease coming out. Guns and spider, yokes (zerks) are universal so you should be able to push firmly and have it fit over the zerk. (a rag and wire brush may be needed if you truck is a dirty girl)
edit to the edit --- just finished. I could hear a crackling sound as grease oozed into sight from shaft. zerk's nipples (insertjokes) are actually ball point valves and when you clean if off you can see it. I got to all 6 at once, which is rare I think, except for having to remove my plastic skid plate to get to the front 3 (left in pic)
front drive shaft showing molly grease (purple) pushing old grease (red) out.webp
^ I use this saint
guys get so wrapped around the axle with stuff on mud...if it's molly it's good IMO
Next up....torsion bar tweak?
AATLAS1X is in process of making roof mounts and a flat rack that will be modular and work with Yakima and Thule accessories. Thread in 100 section.
I ordered front seat replacement leathers from him and spoke to him yesterday. He said it would be a few months out on the rack, but it's coming.
