The nice thing about a 100 is it will be as big a money pit as YOU want it to be. On my 100 the only things that have broken without abuse is starter, alternator and battery. Oh yeah and one rear u-joint that I never lubed up. It has 199k on it.
Do you want a 100? If so, get one.
Seems like a real good price for a 2006. 06-07 still bringing a bit of a premium. I would not be scared of going 120K on a timing belt. 90K seems really early to me. I would do it about then.
Looks to me like a 25,000 offer would work.
I've read a lot of posts on the 2UZ timing belts, and I never found an instance of anyone having a TB failure (at any miles). That's not to suggest that it hasn't happened to anyone or that I would recommend going much beyond 125K on one, just to avoid tempting fate, but I concur that they appear to be very durable!Keep in mind that 2006-forward have a pretty decent bump in horsepower.
I had the timing belt and water pump replaced on mine at 100,000. I think there's some flexibility. Needs to be done though.
Worth noting that I got it done by an expert local mechanic at half what the dealer quoted. I think Grogan had a similar experience.
TJK
lenross1 said:153k & counting on the sequoia. I plan on testing fate...
A snippet on timing chains from Robbie Antonson in the next issue of Toyota Trails.
I do think that if you are in the habit of starting the engine and not allowing the oil to get fully through the engine before shifting the transmission into gear, then you can create some timing chain wear issues (the oil that goes to the head also goes to the oiler that lubes the chain and it does take some time to get oil everywhere). So if you allow the engine some time to get oil fully through the engine, then you should have long life in the timing chain area.
Something to think about.
TJK
Belt on the V8. Chain is for an 80. Todd is lost.
I'm not trying to start anything here, I'm just trying to understand if I'm missing Robbie's point: How does putting the truck in gear speed up or slow down the oiling process? Irrespective of whether the truck is in gear or not, the engine is still running, and either it's going to oil the chain or not. If putting the truck in gear too soon somehow affected oil pressure, etc, then I could understand, but it seems to me that within a few seconds of starting, the engine will develop oil pressure, and with the exception of increased pressure due to RPM, the engine is oiling everything it is going to oil.......again, I could be missing the logic here, that's why I'm asking and not intending to "correct."A snippet on timing chains from Robbie Antonson in the next issue of Toyota Trails.
TJK
Not too many chains on modern V engines....
Ford, Nissan, Dodge, Chevy....
