100 pads stock on 80 ? need a parts guru
I was getting all ready to do the 100 series brake mod, and the parts guy @ the dealership says my 80 already has stock 100 series calipers because of the 6/95 manufacture date.
Is there a parts guru that can confrim the stock replacement is the best I can do ?
You don't have 100 series calipers, but you should be able to fit 100 series pads on the front.
It's a good idea to replace the rotor or have it turned due to the different pads (80 to 100).
I was going to do a combined rotor/pad replacement, I just want to make sure I do the best I can, and get the biggest pad that will fit the rotor.
I will press my parts guy to make sure we are really talking about the same thing. If the 100 serie started in production year '98 not sure that it really makes sense that a 6/95 manufacture date would already be switched over to the new spec.
Does anybody have the P/N for the 100 series pad to be used in this mod? If somebody can post it up, I should probably get the correct P/N for the rotor as well.
Thanks in advance for the help
Call Cruiserdan at American Toyota!!! See the vendor section. There is no finer parts manager for friendly VERY knowledgable service, price an parts availability than Dan.
You can put 100 series pads on an 80. Just loose the shims you use with 80 series pads. Quick search in the 80's section will score you plenty of info on this subject and probably the FAQ as well.
Bump TTT
Can somebody post up the part numbers for 100 series pads & rotors?
Bump TTT
I only happen to work for a parts guru, but I see these numbers every day. :)
Pads: 04465-60220 (100 series)
Rotors: 43512-60090 (80 series rotors)
You cannot use 100 series rotors because they are a 5 lug pattern as opposed to the 80 series 6 lug pattern.
Thanks Mr Beno.
I knew that the rotors were supposed to be stock 80 rotors and it was just the pads that were 100 series, but I lost my mind for a minute.
Thanks a ton
I figure pads are such a common part, I hated to call American just to get a part number when the part itself is probably sitting on the local dealer's shelf.
Thanks again
I would order them from CDan if I were you. You will save a nice little chunk of cash. I did anyway.
I'm a bit of a newb with the 80 so please go easy on me. I bought a set of 100 front brake pads (Ceramix carbon-ceramic) from NAPA and compared them to an old set of 80 pads. The metal back of the 100 pads is significantly larger than the 80's, will they still fit? It also seems like the pistons will press on the back of the pads slightly off center; is this a problem? Was going to just toss them in and let the slight ridge on the edge of the rotor grind down by itself, probably best to turn the rotors, but no time.
That sounds like it could be risky. However I am not a brake expert. I would suggest if possible to hold off and put them in when you can get the rotors turned so that everything goes together as it should.
Couple of things:
1) NAPA pads aren't as good as OEM. They simply don't last as long or hold up as well. OEM are barely more expensive than NAPA, so you'll be ahead by calling cdan and getting OEM pads. They aren't expensive at all if you go through him.
2) The pistons pressing off center is fine.
3) The 100 series pads only work on 93-94 with rear disk and all 95-97. Make sure you have the right year/setup for it to work. Otherwise, you can get them to work but it requires some grinding.
4) You need to turn the rotors. Letting the pad grind down the edge of the rotor will likely end up with a warped rotor, a ruined pad, or both. You're going to generate a lot of heat in a small area, and heat = bad for brake systems.
Do it right or stick with 80's pads. Seriously.
I did just new 80's pads (front and rear), full brake fluid flush, replaced the rear calipers, and replaced rear rotors. The :princess: truck went from stopping like a greased pig on ice to putting you through the windshield. Going to 100 pads will further improve that, which I plan on doing when I do the birf job. The one of the biggest advantage of 100 pads is that they are larger, which spreads out the heat from stopping more, which will really help as we use her truck to tow a bass boat over some very steep hills.
If well maintained an all stock 80's brake system will work just fine. There's absolutely no reason to go to 100 pads unless you turn or replace the rotors, you will simply be making braking system worse.
. . . . . . 3) The 100 series pads only work on 93-94 with rear disk and all 95-97. Make sure you have the right year/setup for it to work. Otherwise, you can get them to work but it requires some grinding. . . . . . . .
I thought the 100 series pads could only be installed on the front. Does this comment imply they can be installed on the rear as well?
100 Series pads- fronts only period on an 80 series.
No. Well, it kinda does, but no.
91-92 and some 93-94 (with semi-float rear and drum) used a different caliper. It still goes in the front, but it's not a straight drop in.
The 93-94's with semi-float rear and drums are relatively unusual, but they are out there.
All 91 and 92 trucks require grinding. On 93 and 94 trucks you can tell which ones do based on if they had rear drums or not.
Not quite correct.
All 93-up vehicles use a larger caliper than do the 91-92 vehicles.
There are three different front calipers:
#1)91-92
#2)93-May 95
#3)June 95-97
The 93-up calipers, although two different part numbers, are almost identical and are unoffically interchangeable.
Bull****.
TO MUCH INFORMATION !!!!!!
Can bigger 04465-60220 pads be installed on the rear of a 6/95, or is the only option stock pads in the back?
(Please don't try and help anybody else in the forum by replying with a comprehensive meaningful answer, and please, keep it in simple one sylable words !)
P.S. thanks for the help everybody, sorry I am such a simpleton
04465-60220 pads apply (sorry, two syllables) to the front only (sorry, two syllables).
No options in the back.
BWAAAHAAAAAAAAAAAAAAAAA!:lol:
Right on, right on!
