I've searched the googles and mud forums and am not finding much. Deets: 2006 LX470, VVTI, 206k miles
I recently got a P0011 code and am not having any symptoms, runs perfectly. I did just change the oil less than a hundred miles ago. I changed the timing belt & water pump a few thousand miles ago and shortly after the truck shut off, turns out I missed tying the camshaft sensor up (driver's side) and the belt cut into it. Dealer changed it and its been running fine since...
The only thing I found remotely close was here: P0021 Code w/ Check Engine Light - https://forum.ih8mud.com/threads/p0021-code-w-check-engine-light.680304/
...but there was no final resolution. Hoping the brain trust here has some insight. THANKS!!
