for HDJ100, higher chance that your AC is ACT/AC1 based. 88650-60830 is ACT/AC1 based as well. most likely you don't need convert anything.Does anyone have an idea of where i can download wiring schematics? I need the wiring diagram for a 2003 HDJ00 Saraha. I am trying to see if i can get the AC amp board to work in my 2005 LX470. I suspect the wiring for the AC is in a different place on the HDJ100. I currently have #88650-60830ac amp board
with MGC signal ties to ground, pretty much you bypass all the control signal to AC compressor. AC will keep running with the engine. although you may not feel that in the cabin because the AC system controller block the cold air duct with accuator.What about the pressure switch? what does that do exactly?
Are you saying the clutch will forever be engaged? I asked on the phone he (installed) said no about ten days ago. The tell tale should be the rpm bump up and down, or hearing it.
I think you're right though it might be forever engaged. How bad is that? From experience, I know when my pressure is low. Cut off high side is middle three hundreds. Low is something like 37. That will still kill the lock. They way I read the book.
I could be wrong.
I have no reason to take my assembly out and short that wire. Otherwise I would.
I have an issue that the AC pump is not turning on, ac will blow cool not cold and engine rpm don’t dip when the button is pressedfor HDJ100, higher chance that your AC is ACT/AC1 based. 88650-60830 is ACT/AC1 based as well. most likely you don't need convert anything.
So it looks like my vehicle wiring is A/CS ALEDfor HDJ100, higher chance that your AC is ACT/AC1 based. 88650-60830 is ACT/AC1 based as well. most likely you don't need convert anything.
No... it is opsite. Let me message you about your solutionSo it looks like my vehicle wiring is A/CS ALED
and you're saying the 88650-60830 Amp board is ACT/AC1 I'll still need to wire in the transistor like your diagram shows?
it would work and I tested with relay method at the beginning. however you dont want to control with LOCK signal since it is a periotic waveform.would a relay as a switch for the MGS with a LOCK trigger still maintain the safety system?
What is the quality of the voltage on the LOCK wire?
Doing some digging, since a lot of people do LS swaps in cars nowadays and they don’t always have a means to wire in the ac, I saw this method-do you think this would add back the protection of the ac pressure sensor…Nice job. finally I know the difference between 60830 and 60B80.
Still I doubt it may bypass the ECU part (pressure sensor), it is not easy to test, I suggest just use as is.
I’ve had a few questions on exactly how Justin hooked this up…
So it’s actually done at the ecm behind the glove box
Pin 31 blue with black stripe gets cut, insulate the wire side coming from the ecm (won’t be used) then cut pin 2 at the ecm blue wire, insulate the wire side coming the ecm (won’t be used) then connect the blue to the blue w/ black stripe together (harness sides NOT the connector sides)View attachment 3608066
these may not apply to toyota world. since a lot of time the output just don't have enough driver capabilities, either pull up or pull down.Doing some digging, since a lot of people do LS swaps in cars nowadays and they don’t always have a means to wire in the ac, I saw this method-do you think this would add back the protection of the ac pressure sensor…
“Attach one of the blue wires on the Binary switch to chassis ground. Attach the other blue wire to the same pin on the fan relay that the ECU grounds to trigger the relay. This way, if you don't have your AC turned on, the ECU alone controls the fans. If you do have the AC turned on, then both the ECU and the binary switch will control the fans.
2. Install a relay up by the fans. Connect one of the relay common to battery power (fused to run the fans) and the N.O. contact of the relay to the power side of the fan connectors. Connect one side of the relay coil to Ign+. Connect the other side of the relay coil to one of the blue wires on the Binary switch. Connect the other blue binary switch wire to chassis ground. This will supply power to the fans whenever the binary switch is triggered and also still allow the ECU relay to control the fans.”
Yes, I didn’t notice it when i sourced and Justin told me when he was installing it didn’t come with the mirror heater button. I’m in Florida so I don’t think i will ever have a problem with frozen mirrors. It was a casualty of “war” LOLthese may not apply to toyota world. since a lot of time the output just don't have enough driver capabilities, either pull up or pull down.
everything needs test.
why one button is missed here?
