My FJ62 is running hot. Almost hit red on run up I-17 towards Flagstaff. I have replaced the following in the last month. Water pump(oem) and Fan Clutch(oem) and most hoses(oem).
During install of fan clutch I noticed a radiator leak from the area of seam between lower tank and fins - not sure though. It is hard to see while it in the truck. I tried to plug with repair kit. Seems to have helped a little bit.
I tested the thermostat today. Opened in hot water about 10mm, in spec. I replaced the thermostat anyway with oem and took another run up I-17. It did a little better. The thermostat I replaced looks nothing like the oem one and was lacking rubber o-seal on top.
Now here is where I may be a penney wise and a pound foolish.
If I was to get it fixed in Phoenix, who should I go to?
I am up-to-date on the replacement choices (oem$550, MAF$625+, Performance Radiator$231).
And, FSM says I have to discharge AC and remove the front of truck to get it out. Is this true?
Since the truck did like highway hills, I stress tested the new Aussie locker in the rear at the Bumble Bee turnoff(pipeline trail). It did really well!
