Poser said:you are correct... the alt and p/s swapped locations....
same belt routing however....
JBBenson said:Is the belt diagram for the 60 the same as for the 62? (See attached)
overhanger said:Schaat's diagram for the 3FE is almost right and I've seen it before. The problem with it, as I see it anyway, is that there are two idler pulleys instead of the single one shown and the secondary alt belt goes around the crank pulley. Otherwise, I believe it to be correct.
JBBenson said:This is better, using terms I know, with 2nd idler pulley.
