Regular fuel vs. Premium Fuel
Grand Junction, CO
Website
westernslopeanglers.com
Experts knock premium
Pricey gasoline doesn't benefit most kinds of automobiles
April 3, 2003
BY MARK PHELAN
DETROIT FREE PRESS BUSINESS WRITER
What difference does it make if you use regular or premium gasoline in your car?
About 20 cents a gallon.
It may be small comfort with gas prices remaining so high, but you virtually never gain anything by running a higher and more expensive grade of fuel than the manufacturer recommended, and you may not lose much if you use a lower grade of fuel, a variety of experts say.
A lot of people fill up with premium every third or fourth tank. Some do it to clean out the engine, some to get a little more power or help an older engine run smoothly.
It's a nice idea, but they might as well toss 20 cents a gallon into a wishing well.
"It's a waste of money," said Harold Schock, professor of mechanical engineering and director of Michigan State University's Automotive Research Experiment Station, which studies combustion systems.
"It doesn't make any difference for most people," Schock said. "Most engines are designed to operate on relatively low-octane fuel."
There is no power difference from high-octane premium to low-octane regular, said Robert Furey, a fuel specialist with General Motors Corp.
"Octane is simply a fuel's resistance to knocking," he said.
"There's no benefit if the octane is higher than the engine needs, but if it's too low, that can cause knocking," he said.
Engine knock -- what happens when fuel in a combustion chamber ignites before it should, causing a disruption in the engine's operation -- used to be a major concern, but devices called knock sensors have nearly eliminated it, said Pete Dowding, manager of Ford's modular V8 and V10 engine program.
Before electronic knock sensors became common, a bad tank of fuel could be disastrous, because persistent, severe knocking can destroy an engine, Furey said.
"If you find your car runs fine on a lower grade of fuel, go ahead," said Bill Hickman, spokesman for the American Petroleum Institute. "We don't encourage people to buy a higher grade. Just follow the manufacturer's suggestions."
Some automakers still say premium is required for their high-performance engines, but even they admit it's more of a suggestion than a command.
"Based on our high compression ratios, it's important to use premium," said Rob Mitchell, spokesman for BMW of North America.
"However, you can run on regular if no premium is available. We don't recommend it, but it won't damage the engine. There is a slight deterioration of performance, however."
Running regular fuel in an engine designed to use premium does reduce performance and fuel economy, Furey said, but too slightly for most drivers to notice.
GM requires premium for just two engines: its supercharged 3.8-liter V6, used in the V6 Buick Regal GS, and high-output 1.8-liter four-cylinder in the Pontiac Vibe GT.
Even the Chevrolet Corvette runs fine on regular, Furey said, although GM recommends premium for maximum performance.
On the other hand, some engines have sophisticated two-way knock sensors, which allow them to generate more power if you use a higher-octane fuel than the manufacturer recommends. Chrysler reportedly fits some of its engines with such sensors, meaning that a fill-up with premium actually can put a tiger in your tank.
I use regular unleaded 90% of the time. The only time it's knocked is when I reverted back to regular octane after having used premium for a couple tanks. Bottom line:::::stay with the regular unleaded, save the money and spend it on mods!
username? said:
where can i buy a two way knock sensor for my 6o?
I think Craftsman makes one ... :D
Bs
my cruiser runs WAY better on high octane!
plus, to all you cheap bastards...., if a tank of gas costs, lets say $2.50/gal? and lets say it goes up, hmmmmm, sumthn crazy like $3.00 (which is kinda unrealistic...even in these times...a $ .50 hike). anyway, in 10 gal of gas, its only $5 bucs more. who give a f@*k? WE DRIVE $ PITS!!!!
i do appreciate the info on high octane vs reg, but im surely not worried about $5 per 10gallons... just my 2c
ps i dont have any kids...FYI, lol!
my green 82 fj40 likes mid grade, it will mildly ping on regular, timeing ect all set to spec.
my fj60 like regular just fine.
I run mid grade in the 100, it calls for premium
90 fj62 likes mid grade better.
64 fj45LV........I could piss in it and it would run fine ;) same with the 45LPB(wtih 2F and fj60 dizzy)
that's probably a real good sign to cut back on the booze :flipoff2:
Unless some of you guys are running high compression motors, nobody should see better performance with high octane. An easy way to put it is, the resistance to knock is related to how fast the fuel burns. The higher octanes burn slower than low octane. That is why if you run forced induction or have a high compression, you run the higher octane for the slower burn, more resistant to knock properties. Because high compression and forced induction create greater heat in the combustion chamber, the low octane fuel tends to pre-ignite, which is, of course, knock. With our low compression motors from the factory, theoretically we should see better performance with lower octane because it is burning faster. To each his own.
I agree, but I use what each cruiser likes best.
Who cares about performance with a 2F anyway? With that tractor motor, no high speeds or great power will come from it. I'm with 87CRUSR, spend the cash on mods.
23.8 gallon tank = $12 wasted on fuel
23.8 gallons every week and a half = $36 wasted every three weeks
52 weeks a year = $624 at least wasted a year
Sounds like some new bumpers to me!!!!
OR A 50 GALLON GAS TANK!!!! HAHAHAHA :flipoff2:
:beer:
i've never run anything but the cheap stuff...no issues.
i run 89 usually. but when i run the next step up it makes a HUGE difference. i can really feel the extra power. maybe its just my gas guzzling 62...
sometimes, during the summer in Dallas, I will mix tanks between plus gas and regular gas as they put additives in the gas for summertime emmissions. I can actually tell the difference when they change it. But, after a good tune up, I always run regular and it works best.
87 does just fine in the 60, but the better-half's Avalon requires the 91 or 92 octane. I've tried to run 87 in it and you can really feel a difference. (And I'm with Pimp - I could run the 60 on a mix of urine, rubbing alcohol and ditch water and it would probably be just fine. :D )
I never noticed a performance difference between 87 and 92 octane in my rig. But I DID notice a slight decrease in mileage (about half a mile per gallon, no wajor woop) in going from 87 to 92. I'll stick to regular 87, thank you very much :D
Ok. Remember who these rigs were designed for.
3rd world militaries and agricultural use.
They use whatever's available where they are, and it's usually low quality and often contaminated.
I run the cheapest s*** in my rig as I can find.
If they still had 40 octane gas here, I'd prolly run it. :) Although when I had a vacuum leak, I had to run 89 when I went to the High Country last summer.
In Phoenix, all gas comes out the same pipeline, and it ain't seperated by pigs anymore.
I only run generic motor oil, ATF and gear oil, too. Whatever's cheapest.
I bet my rig outlasts all you Mobil1 users. :D
All gas (& oil) comes from the same pipe, but it's separated in a refracting tower into an unimaginable number of products before it ends up at your filling station.
Original owner's manual for my '83 says 91 RON (Octane Rating 87).
