Code 0205 & 0206 (1 Viewer)
Jefferson
What do these mean?
Those are injector circuit malfuntions on #5 and #6 respectively. I suspect you have wiring harness issues :princess:
I don't see them in my books, what are you working on?
EDIT: Fast Tom got me......:D
Rogue said:
What do these mean?
I will assume P0205 and P0206.. If this is correct, then check your injector circuit on cylinders 5 & 6...
You guys are fast :flipoff2: :flipoff2:
Here is a link to Toyota trouble codes..
And a link for our Russian speaking friends...
I looked in the FSM too, but didn't see them. Don't know what that means... (we don't have injector circuits in the LC? :D )
But a quick Google of OBDII and P0205 gave me the answer...
BTW...Quick Tom is okay by me, so long as it's not my wife saying it :eek:
It is a '94 if that means anything different...
Pre-OBD2.
I think that means it has the inferior tranny? :flipoff2:
That was "Fast Tom" as in "Fast Eddie".
"Fast Eddie was a flash with a cue, the best ever seen in the second-rate smoke-filled poolrooms of Little Town, U.S.A., but he was on the slow track when it came to life, love and winning the big game in the Big Town"
Paul Newman played Fast Eddie in The Hustler
-B-
B- Too many mixed inuendos for my feeble cave-man brain (ala SNL). :rolleyes:
Rogue: sorry for the hijack and misdirection. Feeling my oats tonight :D But my first instict, having never heard of this code on the LC, is that it could be related to the wiring harness, as in short/burn/egr, etc.
Rogue, how did you get a 4 digit code in a 94? Do you mean code 25 and 26? If so then your air fuel mixture is both too rich and too lean which seems unlikely :flipoff2:
oh wait, i got this off google
Combined Nomenclature 2004 - changes from 2003
* New code
0205 00 Meat of horses, asses, mules or hinnies, fresh,
chilled or frozen :
0206 Edible offal of bovine animals, swine, sheep,
goats, horses, asses, mules or hinnies, fresh,
chilled or frozen :
So...these "spare parts" need to be removed from his fuel system? :D
BTW...good point about the OBDII codes on a '94. :rolleyes:
Great. So since it is pre-OBD2, then these codes are 25 & 26. My mixture is both too rich and too lean. F it. I am going to cover the thing in lighter fluid and roast it tomorrow. I am becoming anti-80 real quick.
In the first link I provided, the folks there have been finding some 94's & 95's to be OBD II compliant... Could be that your '94 happens to be OBD II compliant...
Rogue...how are you pulling the codes? Are you using the jumper? If so you should be counting the flashes. PM me if you need any help...I'm bored at work and could make something up.
