Tidying up my H55 conversion before sending it to the exhaust shop and I'm having a few issues with the clutch.
I can't shift with the pedal depressed. If I start it up with it in gear the rig moves even with the clutch depressed. Obviously it's not disengaging.
73 FJ40...
SBC, H55, Downey bell housing, low profile 11" Centerforce clutch, 4 speed TO bearing, 4 speed fork, Stock 3 speed slave (from previous SBC and 3 Speed conversion), Stock 3 speed master.
I'm 95% certain the disc is facing the correct way. And that's the last thing I want to have to do, remove the Tranny. Other than that the pedal height is correct, the freeplay at the pedal is correct, and the slave is adjusted correctly. The system has been bled 3 times and there's no air in it (pedal feels "right"). The clutch fork throw measures only 1 1/8" when the pedal is depressed. I haven't measured the length of the slave pushrod but it's adjusted correctly so it shouldn't matter, right?
Any suggestions before I drop the tranny?
Thanks.
73 FJ40...
Thanks.
I'm down to San Diego for ten days starting Tuesday nite. I'd sure like to cross paths with you this time. If you need an assist, I don't mind getting my hands (shirt and pants too!) dirty!
Pilot bearing is not outta the question either, but I did emory cloth it and assured it slid smoothly prior to install. I remember reading a post from Woody or Poser about trying to break one free while still installed. Maybe drop the clutch hard? I'll have to look at that again.
