A while back some of you folks made suggestions about which speakers fit into the front doors without hacking apart anything. I believe someone suggested a certain model of Eclipse speakers? The OEM speakers are so incredibly thin.
Yesterday I picked up a set of Pioneer TS-A1371R speakers (the thinnest speakers that store carried). They're nice 3 way speakers, 5 1/4" but if installed flush to the metal opening, the back of them gets in the way of window as it's lowered. I see two choices:
1. Make a spacer so they stick out more and let the window clear (not sure how much space they need, probably a half inch more). But, then the door panel might bulge out a bit, and I'd rather not cut a hole in it.
2. Find another set of speakers. I suppose I could even go for used OEM speakers from the wreckers if someone knows what car has the right size. Or, has someone found aftermarket speakers that are a bit thinner?
Thanks!
Thanks!
