I will try and find time tomorrow to pull mine, clean the connections (they are oil soaked) and check it all out.
Recently I had the pictured unit freeze and break the pin....make sure the unit turns freely before replacing the pin(still available from Toyota]I’m guessing my VSS should not loook like this? Looks like it’s missing the connector pin inside. At least I know why my speedometer and odometer aren’t working.
Yeah thats what I think is wrong with my aswell, im getting a CEL Obd 1 code "42" which is bad VSS. Odo & speedo don't work. Gonna pull it apart & see if the pine is broken.Recently I had the pictured unit freeze and break the pin....make sure the unit turns freely before replacing the pin(still available from Toyota]
93 & older had a mechanical, 94 & newer had an electricalDid 80's in the US have the cable speedo (mechanical) or did they all get the electric speedor? My 3/92 80 has the mechanical version. I have a spare cable (new genuine oldstock) to fit one day as the speedo needle 'chatters' a bit at higher speeds. I would have no idea where to get replacement speedo heads, etc if I ever needed to. So far the odo still counts properly and it's not too far off the first digit becoming a '7' now.
Could you please share the part number.Turns out mine was the gear on the vss sub-assembly pulled the assembly replace shafft with new parts from Cdan all is well now.
That's what it looks like to me as well.Edit: I believe the pin is broken?
