For what year model?
sorry about the lack of detail, its a 1996 and the part number for white is fine, as I looked at it this evening and its def just old white that's on there.
White:
Front fenders, 53852-60060-A0 x2
Rear doors/quarters, 61794-60030-A0 x4
Vertical edges where rear flares meet (black on all vehicles) 61787-60011 x2 61788-60011 x2
More pics for the visual learners like myself.
PS right rear fender
Remove the rear panel to access the 2 10mm nuts
10mm screw under the rear mud flap
HI do you have gaskets for sale
No adhesive on the body-side either. The factory gaskets stick to the flare AND the body. More important for the 95-97 plastic flares than the 91-94 fiberglass flares.
White "pin", flare side, 90249-06132.
Yellow "clip", body side, 90467-09077.
Any Toyota dealer can get them.
Can anyone tell me where's the nut on the bottom side of the rear door's fender? I don't see any bolt on the bottom part of the fender, it looks like a rivet instead of bolt, how do I unbolt or un-rivet that??
My car is a JDM diesel 1HD-FT, 96' spec, if this helps.
Thank you!
My '94 (US model) had a bolt coming up through the edge of the door/rubber trim piece that attaches to the bottom of the fender between the fender flare and the step.
Looks like mine comes with rivet on both door, so I drill the rivet to get rid of it ?My '94 (US model) had a bolt coming up through the edge of the door/rubber trim piece that attaches to the bottom of the fender between the fender flare and the step.
What's the difference between these two?White:
Sorry, I can't say. That's an 8 year old post and I retired almost 6 years ago.What's the difference between these two?
61794-60050-A0
61794-60030-A0
TIA!
Seems like just last year. Man time flys. Word still as gospelSorry, I can't say. That's an 8 year old post and I retired almost 6 years ago.
Do the fenders have to be removed to install the new fender rubber seals?
