A picture really does say 1000 words!
But evidentally each of those words costs you!
Portal Axles Generation III Quote
Every standard axle setup will include the following:
Wilwood disc brakes (heavy duty vented rotor, caliper, and pads)
Drive plate or manual locking hub assembly
Loaded Portal-Tek portal boxes
4340 axle shafts custom built CV Shafts
Custom width SpiderTrax 3 1/2" housings
Center section (Ring and pinon gears, bearings and seals)
F-450 Unit Bearing
High mount steering setup
Standard Axle Pricing: MSRP-- Front Axle : $8,499
Rear Axle: $6,999
Standard axle setups will include the following options:
4340 axle and stub shafts
340 CV Shaft or U-Joint Option
4 Piston Wilwood brakes
Axle upgrades:
300M upper shafts: $1500 PER AXLE
300M lower shafts: $600 PER AXLE
Locker options:
ARB Front Locker: $890.00
ARB Rear Locker: $890.00
ARB Compressor Large: $250.00 Small: $175.00
Detroit Locker (per axle): $550.00
Tru Trac Locker: (per axle): $500.00
Wilwood Dual Calipers: $300 per axle
Central Tire Inflation: $2,200 per set
HD spindle option upgrade: $1,500
Lug pattern: 5x5.5, 6x5.5: $1000
Stainless steel brake lines: $240
Phew, you're looking at buying 2 or 3 'cruisers for that price!
