BullElk
After taking switch panel apart. I can take off switches and manually move small white lever to move all the window except DS rear window. The widow switch on the rear door will make it go down but not up. I even tested PS door switch on DS door and it worked fine....and good PS side switch only moved window down and not up just like other switch. Sooooo.....the problem looks to be on the circuit board on driver door panel.
Any secrets to cleaning or fixing. Is this a common replacement. Like I said I searched with no luck.
ALSO, now the window is down with no way of getting it back up. Any way to manually override the switch?
Thanks
Thanks
