Two questions.
First off if you have a steep drag link angle can you run hydro assist? what "gives" when the suspension travels? I would have to assume fluid in the power steering box? or axle shift? Also would that be incredibly hard on your tre's and fluid?
Second, what are all your guys who are soa and have hy-steer arm doing about your up travel? I don't understand how your tie rod does not hit your pitman arm? As it stands now my tie rod easily gets "even" or above my drag link end at the pitman joint with stock arms.
If I was to get hy steer arms to get a better drag link angle so I can run hydro assist my tie rod would slam into my pitman arm. How are you guys getting around these problems?
