Hi all
Took this from my post in Fj45 forum.
I have been working with the glow system on the truck. Everything has been look/measured and it looks okay. But the glow plug indicator docent glow!
But i have a problem with the cold start, it smokes and stumbles until it fire properly, then it runs nicely!
Then I had a idea - I recently took the glow plugs out to test them and they all worked fine. But I did not pay attention to the number or voltage on the plugs. So this morning I took one out and guess what - 14volt!!!
If I understand this correctly it must be 8,5volt glow plugs?
I guess it means that the 14v glow plugs don't glow that much, when you have an amount of resistance in the wiring and the glow indicator. Which again means less voltage to the plugs and maybe that is why the engine starts with a lot of smoke and stumbles?
What is your opinion?"
The bosch number is 0250202076!
