80 Diesel Expedition Rig, 4bt vs 6bt (or a Toyota engine..)
Hey guys!
I have been thinking about what it is that I am going to do with my rig, a fzj80. Want to begin with the end in mind so that I can map out how to get there and so that all mods will work to that end. After reading several forum posts and considering our desires and lifestyle, we are going to make this fzj80 an expedition rig.
Growing up with diesels and considering them a superior engine, especially for expedition purposes, I would like to eventually transplant a diesel engine. The criteria for selecting the specific engine are fuel economy (60/40 split between hwy and trail), longevity, price and availability of parts. I have used the search function and read numerous posts over the last week about transplanting a diesel into an 80 and have learned quite a bit (if answers to the questions in this post can be found elsewhere, please point me to them!). What follows are some facts that I gleaned for verification and some remaining questions.
It appears the most popular options by far are Toyota and Cummins engines. From what I can gather, the Toyota engines are quieter, more expensive, and harder to find parts for and the Cummins are cheaper, louder, and easier to find parts for. My preference would be to stay Toyota but with the fuel economy and longevity being similar and the price and parts of the Cummins being lower, it makes Cummins nearly irresistible. So, I have settled on the Cummins. Now, that conclusion comes from forum posts and a bit of research and is open to correction and discussion. I welcome both! If my impression of the Toyota engines are off, I could easily be swayed.
So, help me evaluate the Cummins options, the 4bt and the 6bt.
HP: The 6bt provides loads more HP than the 4bt. Does that require changes or modifications to the stock set up of the 80? Seen more 4bt’s in the lighter TLCs but does the 4bt provided sufficient HP for the 6,000 lb+ 80?
Height: Both are quite tall. I have read the the 4bt requires a 4” lift at the least. Does the 6bt require a lift? Is there space for an intercooler on either?
Noise: The 4bt run considerably louder than the 6bt. Not sure if that is a con or not.
Shake: The 4bt runs run rougher than the 6bt. Is the vibration an issue (motor mounts, etc) long term?
Weight: The 4bt is lighter than the 6bt and its somewhat similar in weight to the 1FZ. Does the heavier 6bt require the addition of stronger axels? I have heard rumors that the additional weight is too much for the stock axel, but nothing certain.
Price: From what I can find, the 6bt is often cheaper then the 4bt. However, if the 6bt requires modification for the HP and the weight, then the 4bt would be more cost effective.
MPG: I have found very little information comparing MPG. I would think that the 6bt would have better MPG because it would be running at a lower RPM, though I might be way off. Still learning diesel theory If the 4bt has to be tuned up to provide enough HP for the 80, would that kill the MPG?
Pending correction, answers and discussion, the 6bt is the leading option. I appreciate any comments, ideas, suggestion, contributions, etc. Thanks in advance for them. Let the conversation begin!
Hey guys!
