Has anyone installed a spark plug non-fouler in their 1FZ-FE?
I've searched the site and found little to no accounts of folks using these to help mitigate (even if temporary) plug fouling issues.
My '97 engine's (160k ODO) 6th cylinder plug fouls up in short order after replacing it. It appears there's good spark, and enough fuel is coming out of the injector to cause the VTV filter to saturated with gas from un-burnt gas.
This condition has been going on for a while now. It is constantly popping P0306 (6th Cyl misfire), and P04xx EGR System failure codes. Not a shocker based on the description above. While driving, in OD the engine/truck shudders like a plane reaching a stall point. Turning OD off helps a bit, along with mashing it to WOT. Engine still is producing overall good pressure (per the instrument panel's top left idiot gauge). Haven't found any evidence that there's a compromise of the wiring harness @ the firewall pass-thru, or at the wrap near the EGR. If that was the case, the 6th Cyl's fuel injector shouldn't be squirting fuel in, and thereby I wouldn't be finding gas in the VTV filter and vacuum tubes heading back to the TB.
Short of a engine rebuild to resolve what could either be a valve tube seal failure or blow-by at the piston rings (both cases having been suggested by guys based on my description of the symptoms), I was advised to give the spark plug non-fouler a chance, if at least to provide some relief and time while searching for a replacement/donor engine to rebuild/replace. If that doesn't help, I'll have to yank the harness connector to the #6 injector and truly run on only 5 cylinders. It beats wasting gas and the potential for an engine fire, eh?
So if anyone has used the spark plug non-foulers, I'd like to hear about your experiences. How much did you torque it down? I've picked up the Dorman 14mm tapered non-fouler (#42006) to use.
Thanks, fellas.
Thanks, fellas.
