Lights, Lights, and more Lights!
2KCruiser
Everything 2KRacing, practically live here
SoCal
www.2kracing.com
We have been installing these for a few Jeep owners more often in the last year and I have been really anxious to see how they show at night. So I used a few LED Lights we had here at the shop on the front, sides, and rear. Currently I only have the front wired up, however I have already ran all the other wires and have to just connect them all to the relays and switches. The front is a 21" dual row and let me just say I started laughing when I turned it on. I have 6000K Xtronic HID's in my low beams and Nokya 90w Yellow Highbeams and they do not come close to this LED bar. The four square lights on the side measure 4.5" and are adjusted up for whenever I need them. The rear is a single row 39" which I mounted to the factory spoiler mounts. Came out looking great IMO. I will take some pics once I have all of them connected to show the insanity. :grinpimp:
We sell the front bar for $299, the side square lights are $49 each, the rear is also $299.
X2 on price. More specifically; the front bar.
Edit: Sorry. You were responding as I typed my question. thanks for the price.
I would think that bar on the rear would get some dubious looks from local law enforcement in most parts of North America. It's like a ticket waiting to happen.
I'm not worried about my landcruiser, I have a Supra that gets tickets before it leaves my garage.
I recon I could use one of those little ones on the rear of my rack to light up the fishing spot. How many lumens are we talking about?
Here is the specs on the small sqaure ones.
Weight: 1 lb
Light Output Brightness: 2200 Lumen
Operating Voltage: 10V-30V DC
Waterproof Rating: IP67
Power Draw: 2.1A @ 12V / 1.1A @ 24V
This is front specs,
Technology: 24 x 3w high intensity CREE LED's
Weight: 6 Lbs 14.4 oz
Dimensions: 20.5" x 3.75" x 3.6"
Lumen Output: 8000lm
Operating Voltage: 10-30V DC
Color temperature: Pure White 6000K
Material: Die-cast Aluminum Alloy Housing
Life span: 30,000+ Hours
Specs for the rear bar,
Power: 120W
Lumen: 12000lm
Operating voltage: 10-30V DC
Waterproof rate: IP67
Combo Beam: Flood Beam(120 degree) / Pencil Beam(8 degree)
Material: Black Diecast aluminum housing, PC lens, Aluminum Bracket
Technology: 24 x 5w high intensity CREE LED's
Life span: 30000+ hours
Dimension: 39"x2.8"x2.3"
gotta buil thread of your Supra somewhere .? / videos .. ?
I only have an older video of it. It basically has a 7m with a Turbonetics Ball Bearing Turbo.
Complete tear down with Built Bottom End including JE Pistons and Total Seal Rings, Ported and Polished Heads, AEM EMS, 7 Point Custom cage, it basically was built for road racing. Last Dyno did 493rwhp at 17psi. I have taken to 26psi a few times, massive wheel spin.
http://www.youtube.com/watch?v=Mgei9Ol8AVY
Got all the lights wired up. Ordered switches from Oznium.com which fit perfectly. They light up when on. Yellow is for the front bar. Green switch is for the side lights on the rack, Red is for the Rear Bar. The Blue switch turns on my Radiator Aux fan.
Also rewired my Antenna Up & Down to control my Winch.
Also threw in another battery. Not that the original battery would not handle the extra load, but just because. Which I believe is a great motto around this forum, "just because" ;p
Bought a $40 mount off ebay and threw in a Yellow Top. Connected to a solenoid and Marine Switch, 2 relays, blah, blah, blah, works great. Have not cleaned up the wiring just yet. Plan on installing a 2000+ watt inverter soon as well.
Not (totally) related, but I'm curious about your high beams? Why yellow? They working out well for you? Where did you source them?
