- Joined
- Oct 22, 2012
- Threads
- 3
- Messages
- 12
Fellow Mudders, thought I would start a thread on lessons leaned during my rebuild, and use as a tool to follow up on some nagging issues....
Lessons Learned:
1. Use IH8MUD.com, great resource - need to add a membership fee to the store tab. Still can't figure out how to "pay" my appreciation...Also, if you are considering a re-build you must check out Concrete Jungles thread.
2. IH8MUD is much faster on an Ipad, than on PC.
3. Don't, really Don't, put a gold star here...Don't skimp on the PHH hose....I took a short cut and just used hose clamps and a stock hose, and I have a drip....So what would have been a 5 min/$20 fix with the engine on the stand is now a 3 hour fix in a new yoga position.
and it's more than a Pesky Heater Hose now...
4. CDan is a great source for OEM parts, and by far the best price...I used all OEM parts except for the pistons, hope that does not catch up with me. Even with aftermarket pistons, my total tab is approaching $3,000 (but includes new OEM radiator, water pump and PS pump and about $900 of machine shop time.)
5. Pulling whole drive train is the way to go...
6. Plastigauge is comforting, and worth the extra effort.
7. Fastenal is your your friend for replacement bolts/nuts/screws - especially those pesky Phillips head oil pump cover screws - replaced with nice torque screws, and also replaced the spark plug cover screws, and a-lot of other M#.##x##.
8. Didn't replace the bushing for the PS gear, but discussed it with machinist, and we checked after cleaning the engine without aggressive solvents, trusted his experience and he said it seemed ok to him... I will loose sleep over this, and now that the work is done, wish I had replaced bushing.
9. FPIG is awesome.
10. When started found no power, and wouldn't accelerate, and ex. manifolds became Toyota racing red...after a-lot of worry about engine build found out #2 plug wire was not connected, problem solved...
11. Almost forgot this one - really have to thank the guys over at Rams Cylinder Heads - out of St. Louis. They took my old head that was warped 35 thousandths and heat treated to back within specified tolerances, Decked the surface, reworked the valves and replaced all of the guides and then set the clearances (tipped the stems) for $450 plus shipping which was about $50, and gave me a three year unlimited mileage warranty! This saved the truck from a parting out program
Nagging issues #1:
Timing...Still working on this one...at 3 deg BTDC I get a Knock Sensor code (before I get out of the driveway) and truck is sluggish, especially at low end. At 8 deg BTDC still get a Knock Sensor code (within 5 miles) but engine runs ok. At 12 deg BTDC no knock sensor or any other codes but only ran it for 30 miles (worried about breaking in engine wrong), and engine runs great, with good power...Seems like something is wrong here. So will continue to be a lesson learning. (all degrees are with SST (Paper Clip) jumping terminals TE1 and E1 of the DLC1). Would really appreciate some thoughts here, have read the thread on advancing timing and it seems that there are a-lot of folks running at 8 deg...
So come on, Share what lessons you have learned during your rebuild and help me chase down some of the nagging issues as they come up...Let's start with the timing.
Lessons Learned:
9. FPIG is awesome.
Nagging issues #1:
