As you know I am up in arms about what to do about sliders and came up with an idea that I would like some input about. I don't really like typical tube sliders and saw these for Jeeps:
I really like the look and should be easy to make with the proper sheet metal brake. The hard part would be frame attachment since the frame is not a straight line front to back. I was thinking it would be fairly simple to keep the bottom flat and weld it straight to the bottom of the frame, then you could just cut out the right shape. Maybe some gussets at the bend for strength. I am going to run a couple bullet cats so this should eliminate the only low hanging parts. Am I out of my mind (it is late and I am up past my bed time) Will something like this support the weight of the truck or just fold up? Looks like they make something similar for the 4-door model Jeeps so I would think it might work.
Jeep Brawler Rockers | Jeep Rocker Armor | Poison Spyder
now that I'm thinking about it, sounding interesting. Will probably be heavy depending on how thick of plate you used.
