I don't think the additives have anything to do with cavitation cosidering what cavitation is. ...
A little confused, please elaborate? This is how I understand it in this application:
Cavitation is vapor drawn in or formed on the suction side and imploding on the pressure side of the pump.
The fluid is a cocktail of chemicals, some can change how others react, but for the most part, the performance of each chemical molecule is mostly governed by it’s characteristics.
For this example will keep it simple, base oil and an additive water. The base oil has a boiling point of about 600F and water at 212F. The oil will pass through the pump without issue. As the fluid is pulled into the pump, the suction and turbulence at pump entry reduces vapor pressure/boiling point of the fluid and the water molecule flash boils into vapor. A fraction of an inch/second later it’s slammed under pressure causing the vapor bubble to implode. The implosion causes heat, some of the surrounding oil is consumed/burned, can pit metal, etc. It’s the number one cause of pump and fluid wear, causes most of the varnish deposits in hydraulic systems, etc. It very often happens because of vapor formed at the pump entry, with no leakage, outside vapor.
Mild cavitation can happen without being noticed, but the groaning that is heard is lots of implosions happening at the same time, any of it is destructive. The composition of the fluid has a lot to do with it, as the fluid ages it degrades and becomes contaminated, so fresh fluid is good. Also anything that increases suction will make it worse, like reservoir being mounted too far away or low, small feed line, screen, filter between the reservoir and the pump, etc. Ideally the reservoir is mounted over the pump with a large line going directly to the pump inlet, like it is on the FZJ80.
