- Joined
- May 31, 2009
- Threads
- 10
- Messages
- 43
Today I changed the oil in my 96 for the first time. I had quite a bit of trouble getting the oil filter off because some idiot at the last place where the oil was changed (previous owner, filter was "firestone" brand) decided it would be a good idea to put it on with about 1000 ft-lb of torque. So I was left with the task of figuring out a way to get it off. I tried all the usual tactics; rubber band wrench, poke a screw driver through, twist by hand. All failed mainly because I did not have enough access to get them to work properly except my hands which apparently weren't strong enough. In the end I used part of a ratchet strap with a metal hook on the end. I inserted the hook into one of the holes I'd made in the side of the filter and then wrapped the strap around a couple of times. Then I stood on the bumper and pulled on the strap until the filter started turning. The main reason this is a good method is you get to apply the force to the strap from outside the engine compartment leaving you plenty of room to really get your weight into it. By the time I thought of this idea I had almost completely destroyed the filter from my other methods. Be careful not to get debris into the engine if you are destroying the filter as you try to take it off. I saw no evidence of debris in the inlet or outlet ports so I think I'm good. Hope this helps somebody sometime in the future.
. I had a similar situation yesterday; I could not get the oil filter off from above no matter what I tried, so I put the rig high up on a lift and while standing underneath reached up with the metal band type filter wrench got it on the filter and with my body weight hanging on the wrench was able to get it to break loose. Then I lowered the rig and removed the filter from up top. Probably not a new idea, just I had never thought of it before. If working in the driveway without a lift this could still work, just haven't tried it yet. It would really be nice if every manufacturer put a nut on top (like bignasty suggested) or maybe even a square slot on the top of every filter that something like a 1/2inch ratchet extension would fit into
