made you look!
I posted last on this thread (post #51)
https://forum.ih8mud.com/80-series-tech/281596-who-has-removed-their-egr-valve.html
RE: 2/93 '80, non california emissions, no temp sensor in the EGR valve.
anyone have this and is there a lot of difference from one with the sensor? I'd like to trick the CPU using the 1K OHM resistor, but does my truck look for the signal or what?
partly melted plug is the jumper that Mr. T put there from the factory, and the bolt/plug that fills the port where the sensor ought to be is just that. I have to assume that the EGR system is functional or the plug would not be melted, but can I presume that without a watchdog on the EGR valve/temp the CPU does not care if it sees the right temp, and it will not throw a code or CEL?
I need to OHM the plug now that I think about it, could it be a factory fooler????
nope- 0.2 ohm
nope- 0.2 ohm
I'll have to make two trips to find out I guess...
