Pros Cons on not grinding valves at head gasket replacement?
Is there a risk of early ring failure if you do it?
Are the valve seals at risk and will fail soon?
I would think the head will function better if the valves seats mate like new.
I've been warned that it may cause ring failure and I shouldn't.
Others obviously would do it.
Not sure now and could use some suggestions.
History:
Discovered coolant in my oil and white smoke.
I took my head off, ordered gasket kit and other misc. parts to replace while doing the work. I took the head to a local crank and head grinding shop. I asked that they clean and scrape the gasket marks off the head. I didn't know if i was going to have the valves ground and reworked. Frankly this isn't something I have done and don't have the tools either.
1994, 160,000 +/- miles
Basically Stock
History:
Basically Stock
