I just got my LC. One of the things I noticed before purchase was a vibration coming from when the fan was turned up high.
I figured it would be an easy fix (and it was).
Under dash on the passenger side, there is a black fan housing. Remove the 2 Phillips screws.
You can see the the fan now. Un-clip the warning harness, and remove the 3 torx heads.
Prepare for ugliness.
Yes, that's an acorn, feathers, and misc other schmutz. The fan didn't want to come off the motor shaft, so I just carefully cleaned with a toothbrush.
Looking back up in the dash, I noticed a good amount of lint, so I took a vacuum to it also.
After putting it all back together no fan vibration is noticeable. I wonder if I should take apart the big A/C box next to the blower??? to much trouble?
