Clean that AC / Heater Blower
Some stainless mesh on the underside would be useful, too. Rodents are persistent - ask me how I know 🐀
Man I was all up in there and I don’t see an easy way to install anything from below. Is everyone removing the upper cowl to install this stuff?
To get to the HVAC system air intake "tower" from the top you would have to remove the cowl (remove both wiper arms first then 6 screws using a small 1/4" ratchet) then remove the plastic grills. Here's Outsane's video showing the cut he made during the design-build process for the filter. If you have thick arms/hands it's a bit difficult to reach into that area via a factory opening but doable.
Scroll through this link to watch Outsane's videos:
I’ve been getting a loud noise when turn on the heat and I definitely have some leaves in the front cowl probably but that’s a different cleaning task. I also know I have a mouse somewhere. I removed the three torx screws and found this, not too bad I thought.
I was finally able to clean out the fan and condenser compartment. Luckily just had a few pine needles and the condenser area was vacuumed out. Was able to remove and clean the fan blades, blow out the electric motor (way dirty) and oil the motor. Ready for summer.
