Intermittent Wiper mod from fixed to variable delay
Newcastle, Australia
Standard fixed delay in a 62 series is 4 seconds.
For about $5 and half an hour's work you can change this to a variable delay continuously adjustable from 1.5 to 15 seconds.
I've wanted to do this for some time and kept hoping that someone (else) would do the experimenting and publish a howto . . .
So I pulled mine apart and reverse engineered the circuit and it turned out to be very easy to do. I've been using it for some time now and it is a vast improvement (at the short end a 2s delay is ideal for drizzle while 12 seconds is great for fog).
Modifying the Toyota Landcruiser 60 Series Intermittent Wiper Circuit
Skip down to 'Modifying It' if you don’t need to know how it works . . .
Overview –
The wiper stalk holds 2 switches – a simple ON-OFF for the washer and a four position OFF-INT-LOW-HIGH switch for the wiper motor. There are 3 relays between the switches and the wiper motor, one controlled by each of the INT-LOW-HIGH switch positions.
The WASHER switch directly connects the powered Washer motor to 0V to operate.
The PARK switch (inside the wiper motor gear housing) provides +12V power to the LOW and INT relays OFF positions while the wiper blades are away from the Park position. At Park it switches not just off, but connects the INT relay normally closed contact to 0V. This connection to 0V greatly simplifies the electronics required for the intermittent delay circuit.
The INT and LOW relays pass the state of the PARK switch when the switches are OFF or +12V when they are ON, on to the HIGH/LOW relay. INT adds a 2-way time delay circuit, when ON it turns its relay ON for 0.5s to start the wiper motor, the PARK switch then provides power for the remainder of the cycle, it then stays off for about 4s before repeating.
The HIGH/LOW relay selects routing power either to half the motor coils (LOW speed) or all of the motor coils (HIGH speed). The High switch turns on both the Low and High relays.
The Intermittent Wiper Circuit –
While ever the ignition is ON a 43,000 ohm resistor and a 100uF bi-polar capacitor are connected between +12V and 0V (through the wiper park system). The capacitor charges towards +12V.
When INT is first selected the power stored on the capacitor immediately flows through a diode and a 2,200ohm resistor to switch on a transistor. (A tiny amount also passes through a 47,000 ohm resistor). When ON the transistor switches the INT relay to send +12V to the wiper motor.
When the relay operates the +12V and 0V connections to the capacitor are reversed via the INT relay AND the PARK switch (the 43,000 ohm resistor acts as an isolator). The voltage on the capacitor drains rapidly through the 2,200 ohm resistor and continues to fall too well below 0V (to about -8V). It takes about 0.5s for the voltage to drop low enough for the transistor to switch off, but by this time the PARK switch is supplying +12V to the OFF position of the relay so the wiper motor continues to run.
After a full wipe cycle the PARK switch will again swap the +12V and 0V connections to the capacitor which will start to charge up from -8V towards +12V. The rate that it charges is controlled by the 43,000 ohm resistor letting +12V in while the diode, 2,200 and 47,000 ohm resistors are letting some leak out. It takes about 4s to rise high enough for the transistor to switch on at which point the Intermittent action repeats.
Modifying the Delay Times –
The 43,000 ohm resistor sets both the time for the PARK switch to take over powering the wiper motor and the time between wipes. We can replace the one, fixed resistor with a combination of a fixed resistor (sets minimum delay time) and a variable resistor (sets maximum delay time) – within reason.
Toyota have chosen conservative values for the timing. In fact we can reduce the value to 10,000 ohms or increase it to 150,000 ohms without creating too short a start time or too long a pause time. A good choice is 22,000 ohms fixed resistor (start time = 0.25s, minimum delay = 1.5s) plus a 100,000 ohm (total = 122,000 ohms) variable resistor (maximum delay = 15s).
Modifying It –
You need –
a) 22,000 ohm resistor, 4 colour code is red, red, orange, gold or 5 colour code is red, red, black, red, gold (one eighths or one quarter watt is more than adequate power handling)
b) 100,000 ohm potentiometer, usually marked B100k (A100k=log type, works too). [Most electronics stores expect the customer to fit a washer and clamp nut to the potentiometer from bulk bins – you need these!]. 16mm diameter is a good fit for the dash switch panels.
c) knob to fit the potentiometer shaft
d) around 1m of insulated hookup wire.
e) hand tools, including a small soldering iron
Step 1 – unplug and remove the INT Relay from beneath the dashboard (for right hand drive it’s the grey box bolted in just above the driver’s left knee, left hand drive = on outer wall to left of driver's knee)
Step 2 – open the box and remove the circuit board – there are 4 plastic clips hidden under the overlapping lid, use a small flat bladed screwdriver to ease these open.
Step 3 – remove the 43,000 ohm resistor (yellow, orange, orange, gold) by melting the solder and pulling out. Clear the holes.
Step 4 – drill a small hole in the top right corner of the board, away from electrical traces.
Step 5 – fit the 22,000 ohm resistor. Put one end into the new hole, wrap the end of the lead wire around the board back to the top, then around itself. Put the other end into the lower hole and pull through until the resistor is flat against the board.
Step 6 – solder the resistor and 2 insulated wires, one to the twisted end of the 22,000 ohm resistor and the other to the empty hole. Trim the leads.
Step 7 – route the wires around the pins and relay (as shown).
Step 8 – solder the potentiometer onto the wires, centre and one end.
Step 9 – Plug in to car and test. If the knob turns the ‘wrong’ way swap the outer wire to the other end on the potentiometer.
Step 10 – glue the wire joints to the circuit board after testing (hot-melt is fine); this prevents the wires touching due to vibration.
Step 11 – cut a slot in the case to allow the wires to emerge then re-assemble the circuit board into the box. Fit the lid
Step 12 – install the relay under the dash and the potentiometer to a dash panel (flatten the lock tab) and fit the knob. If you use a ‘linear’ potentiometer it can be fitted to the back-side of the control stalk, but I’ll leave installation there up to the eager experimenter.
Pictures to follow.
bye.
I took a wiper control out of an 87 4Runner and it plugged in my 84 FJ60. The FJ60 uses a mechanical timer under the dash for the intermittent. The only thing I need to do is change the hazard switch. Ill post up more details later.
Awesome. Already got figured out how to do a linear potentiometer (as far as mounting location). Need to find out if that style is available in a solid state / magnetic flavor though, for the sake of longevity and smooth operation. Be great to be able to fine tune the wiper delay on my 62.
What gauge of wiring did you use, and what was the power tolerance of your potentiometer (or does it matter)?
Wire size question.
Work it out from ohm's law [V=IxR; or I=V/R] -
12V / 22,000 ohm = 0.5mA [very low current]
12V / 122,000 ohm = 0.1mA [even lower !]
And from DC power formula [P=VxI]
12V x 0.5mA = 6mW [super low power]
12V x 0.1mA = 1.2mW [practically nothing]
So the wire size to the potentiometer is for strength and durability, the voltage, current and power are trivial. Any potentiometer will handle 6/1,000s of a watt.
bye.
[PS It's been raining steadily here (Newcastle, Australia) for the past 3 days and it has been great to *NOT* have to keep constantly changing the wiper between OFF, INT and LOW, only the occasional pause time adjustment is needed as the rain increases or decreases.
bye again.]
You are my hero.
Do you know how often it's 'sorta raining a bit' around here?
+1 on the FAQ!
t
I was under the impression that you could swap in the turn signal switch from other early 80s Toyota models and get variable delay on the wipers. However, I could be wrong on this.
Howto pictures
Pretty simple really
1) Un-mount and disconnect the relay.
2) Open the case.
(see diagram in original post)
3) Unsolder the 43,000 ohm resistor, clean the solder from the holes,
Drill an extra hole.
4) Solder in the 22,000 ohm resistor, two wires and the 100,000 ohm potetiometer.
5) Cut a slot in the side of the case and assemble.
6) Install.
enjoy
Where did you get that surface mount potentiometer? I might be stuck using onf like that if I can't pull off my idea.
Ya, my memory is my intermittent is mechanical - what year did it change? And can we swap the newer, electronic one for the mechanical one?
*WRONG INFO -->* I think you'll find they are all electro-mechanical using this circuit and a loud clickety-click type relay. *<-- WRONG INFO*
Thanks Dynosoar for opening your 1982 'relay' to reveal an electric motor driven switch. Anybody tried the 1987+ relay in an early model ?
They are very easy to remove from the vehicle, so could you have a look and tell us all please?
Oh, and if your truck is left hand drive tell me exactly where the relay is located and I'll edit the original post to include that.
bye.
The relay in my '82 is different. there is a little electric motor with an eccentric end that opens up a set of points. The speed of the electric motor determines intermittent , slow and fast.
Dyno
Pics of Early 1982 wiper relay.
Dyno
A few more.
Dyno
Wiper info request
Ok further research (and help from other mudders) tells me that there are 3 different intermittent controllers for the 60 series (Australian models).
85940-90A01 is for 1981 to 1984
85940-90A02 is for 1984 to 1987
85940-90A04 is for 1987 to end
I know the 01 is motor driven switches and
the 04 is electronic control of a relay.
Anyone know what's in the 02?
As I've seen these listed at over $150 (second hand!) I think it may be useful to create a universal replacement circuit. Give me the data and I'll try to design it.
Does anyone know about interchangeability between the 3?
Can anyone help with an internal circuit diagram or two?
What's the extra pin for in the 01?
etc ?
bye.
