My 4wd solenoid shifted into 4wd but not out. I reversed the vaccum lines and hit switch, that took it out of 4wd. That being said, is it possible to repair (instead of replace) the solenoid since only part of it isn't working?
there are a bunch of selnoids from many years of toyota that will work, one that comes to mind is an early 90's celica, i have a few of them new in the box in the shhop, but that was the last of them in the system
there was a write up in Trails last year about using a different selenoid
Just for reference for other people with our issue: The 4wd solenoid is located on the passenger side firewall. It is the red one on the bottom. See pic below.
For reference: This pic is from a 1988 FJ62.
zoomed out pic for reference:
Do you, by chance, remember about what issue?
Ive got em stacked in my office (el bano), but if you happen to remember off the top of your head that'd be cool...
Chicago
JRIMS,
I just ordered the idle solenoid from a 4 cyl 22RE engine. I am going to try replacing the 4wd VSV which is the burnt out, same as you. I if i can make it work then I will post it for everyone. I will keep you posted. Realistically this won't be finished until July. Stick to switching the tubes for a bit.
-Randy
Jan/Feb 2007 the one with the multiple pics on the cover
I just replaced my Solenoid for $17 today! I will post pics over weekend and link to a soon to be FAQ thread. I used the "Magnet Valve" off a 4 cyl 1988 toyota pickup. It's off the engine which I believe was a 22R. Please stand by, I will post P/N's and pics.
-Randy
pm me if you want to order is sooner and I can find the P/N while I'm making the post.
