where is your arb compressor mounted??? i can find any free space that i like. im going out to look at it some more. could use some help, thanks
Rear quarter panel for me as well. Simple 1/8" plate bracket worked to existing holes.
Bring wiring and air line through drain plug holes with new grommets and a little sealant.
Jim made me one like the one you see above (actually, the one above looks fancier!) It bolts to existing holes in the frame and sits nicely between the inner fender and motor.
being under the hood, it was easy to wire and plumb it.
Anyone making this or a similar mounting platform? Looking for off-the-shelf solution to mounting an ARB compressor and axillary fuse box around the passenger fender area without drilling into metal on the rig.here's one i've made for myself.
i've made a few for others also.
edit: this is in my 60 with a 2f
will also fit with a SBC
View attachment 169725View attachment 169726
