When I bought my FJ40 a Delco 10-SI alternator was already installed, and things have been working fine for years. Today the alternator died so I replaced it with a remanned 10-SI unit. The problem that has cropped up with the new alternator is that the engine (a 2F) will not shut off when the ignition is turned off. The alternators are of the same type so this is a bit of surprise.
Now how to rectify the problem?
Do I need to intall a diode into one of the wires, and if so, which one? With the spade connection the upper wire is white and maybe 14 gauge while the lower is red and maybe 12 gauge.
Would swapping the position of the white and red wires do the trick?
